ORIGINAL: Boomerang1
Never owned one but from the one's I've seen fly (and crash) the Viper jet appears to me
to be one of those planes that, if not set up exactly right, with conservative CG & control
throws, is a nasty piece of work waiting to bite you.
Of course, the bigger they are the more forgiving they are like most models.
But when you get a small one, heavily loaded, built with all the precision & care you would expect
from Hobby King ...........
John.
Well I have owned one and I can tell you that you coudnt be more wrong in your opinion.
The reason there are crash videos..Is because ProDesign(the manufacturer, NOT HK) posted the wrong CG. I was the first one to post video of the plane flying with the correct CG and it flys just like a really fast Cessna.
As for your comments about setting is up correctly with the right CG and throws... Does that not apply to EVERY! model out there?
Clearly you are a HK Hater so we will just dismiss your comments as it does nothing to help the OP.
