RCU Forums - View Single Post - Engine, back plate troubles
Old 11-10-2012 | 05:20 PM
  #41
da Rock
Default RE: Engine, back plate troubles
Any pushrod in a tube should move with no resistance at all.
A throttle tube that is plugged can simply be ignored. Snip it off on both sides of the bulkhead. Drill it out or cut it out. Run a new tube.
The tubing size isn't critical. Anything close to what is there will work.
