ORIGINAL: acerc
I measured the ring gap of the stock ring before removal and the FB prior to install. The FB was much closer and fit the pin much better.
I normally use a synthetic @ 40-1 from the start. But it takes so long to break in. Would like to get there a little sooner to compare the two CRRC's and two DLE's. Am really interested what the difference will be.
Just keep using your synthetic at 40: 1. The Frank Bowman ring will break in faster all on its own.
Bowman’s Rings
Email:
[email protected]
<span itemtype="http://schema.org/LocalBusiness" itemscope="" itemprop="worksfor" id="works_at_company_name">
<span itemprop="name">Bowman's Rings Model Airplane</span> </span>
<div itemtype="schema.org/PostalAddress" itemscope="" itemprop="address" class="addr"><span itemprop="streetAddress">1211 N Allen Avenue</span>
<span itemprop="addressLocality">Farmington</span>, <span itemprop="addressRegion">NM</span><span itemprop="postalCode">87401-3568
</span><span itemprop="telephone">(505) 327-0696</span></div>
