ORIGINAL: sopwith
P.S What is the typical compression test reading on these small engines?
I do not know if what I do is the right way or not but this is what I got
Hand flipping as hard as I could 8 times
Stock ring about 65 PSI
Bowman ring 85 PSI
Turning engine with a electric starter
Stock rings 95 PSI
Bowman rings 120 PSI
As for the post about pre breaking in rings, There is a little more to Bowman rings than breaking in, They have a better ring gap and with stock ring they will even have a bigger gap after they are broken in.
Milton
