RE: apache owners
Hi guys
heres my 58" Apache by Martin over her in the uk, based on the RCMK theme. running the K600s ( stock ) ive changed the coils to Zenoah and replaced the iso blocks to ali ones. running a pair of MHZ waterpumps via modified under hull pick ups.
Clutch / Gearbox by WD200 as is the steerable drives, all rails a carbon other than the main engine rails which are carbon - Ply - Carbon laminated with epoxy under a 1 ton press then CNC machined to shape.
Radio is Futaba 4PK 2.4Ghz, running a pair of BLS-157HV servos ( Total 74KG ) on 7.4V, throttle servo is a S3501HV, Failsafe is from Killer RC SuperBee Twin.
Pipes are QD Deep "V" mated to MHZ angled flanges, all up weight is around 16kg.
The props are 6717/3s by Chris Dasboata turning Outwards direction.
Bob.
