ORIGINAL: amram
Hi Itzik,
The way your Motor and SC are positioned, maybe a small opening on the back of the bally-pan will improve cooling by creationg s short exit pass for the air...
Amram
Hi Amram,
The way the ESC is positioned provides enough cooling to the ESC but it also serves as an air deflector which aims the air to the motor battery and helps to speed up the air passes around the motor battery.
I like the motor battery to have air cooling as much as I can.
Best regards,
Isaac Najary
