RCU Forums - View Single Post - OS SF ABC advice?
Old 11-11-2012 | 12:53 PM
Dave Harmon
Default RE: OS SF ABC advice?
ORIGINAL: countilaw
I have several .61 SF, and the parts are getting harder and harder to find. Rings and bearings are plentiful, but to replace a sleeve, piston, rod, crank or a case are next to impossible find. And if you did find them the cost would be more than a new engine. The SF swings a large prop and preferrs a RPM in the 11 K area.
I would recommend a new engine like the Jett, Navorossi, YS or even Evolution .61 NX.
It would depend on the type of pattern plane you are looking to build or have.
Frank
Right Frank......
Like this one.
I have not run it yet but when I do you'll probably be able to hear it.
For the record....the model number of this engine is 206R61
ID:	1819497   Click image for larger version
ID:	1819498   Click image for larger version
