ORIGINAL: amram
HI
OK, I understand your point. Don't you concern that the air passes to the battery area is relatively hot as it comes from both Motor and ESC?
Amram
Hi Amram,
You were right if we were talking about something like air-conditioner radiator, but in our case the contact surface of the hot elements (the motor and the ESC) is so small compared to the air mass that is passing through so the air temperature rises very little.
As long as the temperature of the air passing though the battery is lower then the battery temperature itself it is still good.
Best regards,
Isaac Najary
