RE: OS SF ABC advice?
Hi RCGUY59,
That pinch at TDC is supposed to be there. On ABC engines when running the cylinder and piston expand at different rates to get the tolerance needed to run those rpm's. The fact that it is still there after all of this time means you have really taken good care of it, used good fuel and haven't run it lean.
