ORIGINAL: 77chickenhawk
I don't understand the whole drop-in thing for the CJ retracts. Because the wing landing gear mounting blocks are in the wrong location so I don't understand how you can just drop those. From my experience No matter what gear you have you have to bash the landing gear section of the wing
Century Jet maybe making a drop-in replacement with struts that work. I agree that it would be better to put the gear blocks in the correct position for a couple of reasons. One looks better and also the stock gear mounts are kind weak, and would be better to make new ones anyway.
By the way Yellow Aircraft Zero is the same size at 80" wing span so the Sierra gear should be the right size but would need to make new gear mounts to make them work.
