RCU Forums - View Single Post - VectorFlight Sukhoi ARF tips wanted
Old 09-11-2003 | 03:50 PM
Ross Airforce
Default RE: VectorFlight Sukhoi ARF tips wanted
If you are taking off asphalt or concrete or hardpack, you don't need to shim the landing gear! If it's noseheavy add weight as required.
Did you externally brace the horizontal stab? If not, do so, and that will add some tail weight. It will also save the airplane! (Stabs fail easily)
Good luck
