RCU Forums - View Single Post - Flying to the clouds
Old 11-12-2012 | 09:02 PM
HoundDog's Avatar
HoundDog
My Feedback: (49)
Default RE: Flying to the clouds
<h3>Did you read the November 2012 issue of Model Aviation pg15 Titled Congress has Spoken: did the FAA listen ... After reading this and what I know about the FAA after being in General Aviation since 1970 I would be very wary of flying any RC air craft at any place but sanctioned fields. If flying FPV (first Person Video) it should be done per the guide lines set by the AMA. Remember most all hospitals have a Heliport with a federal ID associated. Flight for Life Helies arriving and departing rarely exceed 500 ft AGL. With the pending Legislation by the FAA and the UAPO ( Unmaned Aircraft Program Office) now refereed to as the (UAS) Unmanned Aircraft Systems Integration Office, I'd be very wary flying any RC aircraft (FPV) or other wise in the vacinity of any full scale Maned air craft or airport. We have 2 RC fields on the north side of Phoenix that have been restricted to a mandatory maximum of 400 ft AGL. This has severally curtailed IMAC, Jets and Even Pattern flying, not to mention any soaring activities. It's best to be warned than create an incident and be sorry. Here is a Couple of URL's that will allow you to determine the location of all Federal Registered Airports in your area. </h3><h3>http://aeronav.faa.gov/afd.asp#results </h3><h3>http://www.faa.gov/air_traffic/flight_info/aeronav/productcatalog/supplementalcharts/airportdirectory/</h3>
