RE: Question please: need answer.
Mini servos ( not to be confused with Micro Servos ) are often just as torque capable as standard servos.
Most replacement mini servos are in the 30oz/in range or up, which is fine for any 40 size plane.
At worst you could replace them with high torque mini servos but I doubt you'll really need to unless you are planning on flying the plane MUCH faster than it was designed for.
