RCU Forums - View Single Post - Balancing a Trainer
Old 11-15-2012 | 07:20 AM
bkdavy's Avatar
bkdavy
Default RE: Balancing a Trainer
I like to find the location in the fuselage where I'm going to put the weights, make a clay model of the weights, then make a plaster cast from the clay. Melt the lead with a ladle and soldering torch, pour the lead into the plaster cast, then fix the weight in position. Yes I do this in a well ventilated location.
For what its worth, I always believe if you're adding nose weight, you just don't have a big enough engine.
In my experience, most trainers do not need any weight added for balance. They're normally able to balance by moving the battery and reciever.
Brad
