RE: G62 Cunningham Conversion
Dennis, open up the pump side of the carb and put some fuel there. Sometimes the pump side won't work until it gets wet. Prime the engine also to get it running and all should be fine.
One last thing, did you assemble the carb diaphragm and gasket in the right order?? Also the hole that is plugged is not a fuel line but the old pulse line
