RE: Balancing a bipe
Droop a string over both wing's as close to the fuse as you can. The string has to reach below the bottom wing both front and rear. Measure the distance of the string, this will give the total of the the top leading to the bottom trailing, edges. Balance 30% of that measurement from the front of the top wing close to the fuse. That's how I do it anyway.
