RE: RC Surfer
Hi Curls.....
As with actual surf boards - paddling a 'Long Board' is easier than paddling a 'Short Board' - if the payload is kept consistant - however - with regards to a bigger ******** - the actual weight is increased by its mere size and the added lead to provide the righting action,( remember - the greater the boards volume the more weight you need to right it) then the size of the power-plant needs to be increased to drive it, increasing the weight further....making the bigger ******** less efficient than a smaller ********.
Bro ********. ...
Share the STOKE !
