RE: OS SF ABC advice?
You can have the sleeve chromed with real chrome and then honed to match your piston. Contact a guy named Robert Oge and he can set you up. he will also chrome the crank pin which will make the engine last even longer. This guy is well known in the control line world. He also recommends upgrading the rear bearing since the stock ones do not hold up too well.
