RCU Forums - View Single Post - Another Eindecker build
Old 11-16-2012 | 05:42 PM
  #56
akbowen
My Feedback: (7)
Default RE: Another Eindecker build
I'm currently installing servos and pushrods. Rudder and elevator are done. BUSA recommends placing them in front of the wing bolt down block for balance, but I figure with a big honking engine up front, radio battery, ignition battery and ignition module to place in the nose of the airplane, it wouldn't hurt to move the servos a couple of inches to the rear. I was having a real problem finding a way to work the throttle until I notice a machined throttle arm extension that came with the engine. Problem solved, but I will have to angle the pushrod to get the best movement on the throttle. Also, I'm going to have to pick up a ball link for the throttle pushrod.
ID:	1821040   Click image for larger version
ID:	1821041   Click image for larger version
