RCU Forums - View Single Post - 1650 problems
Old 11-17-2012 | 03:07 AM
K Jorgensen's Avatar
K Jorgensen
Default RE: 1650 problems
Hi Tony
Last weekend I finished the repair and rebuild of a friend SimJet 3000. I did not have a data cable to connect the ecu to a pc. So I could not download the full software. But I saved the parameters that I had access to with the data terminal.
Start menu:
Pump Start Point AUTO +3
Pump Start Ramp 006
Glowplug Power 045 (using 2 cell lipo)
Gas Start Adjust 100%
Low Batt Volts 6,2V
Run menu:
Full Power Speed 110000 – 120000rpm (depends on what you had the engine running)
Idle Speed 32000rpm
Stop Speed 20000rpm
Start/min temp 100°C
Max Temperature 800°C
Acceleration delay 025
Deceleration delay 015
Stability delay 050
Pump Limit 1000
Hope you can use it
Some picture of the repair / rebuild
Best
Kim
ID:	1821139   Click image for larger version
ID:	1821140   Click image for larger version
ID:	1821141   Click image for larger version
ID:	1821142   Click image for larger version
ID:	1821143   Click image for larger version
ID:	1821144   Click image for larger version
ID:	1821145   Click image for larger version
ID:	1821147   Click image for larger version
