Not sure what you mean by holes the size of Texas. Clarks in regular contact with the fellas on rctank regiment. When there have been function issues (range and damage simulation) he's worked to resolve them with total success. He's in Taiwan so things take time if returned. We have extensively tested the Clark board today and achieved over 100ft ir range with the tbu. So you've got good sound, Tamiya compatible, high degree of customisation and it's only the same cost as 2 rx-18! As dan said a slightly more
Powerful card with wifi and fpv is in the works. Also a version with momunteum has been proposed. Most of the guys at our club are running them very successfully!
ORIGINAL: FreakyDude
hate to say it but the lowest cost right now is the Clark board but and this is a big but the service has holes as big as texas in it.<div></div><div>whats your budget? the amount of money you want to spend will or should be the deciding factor.</div><div>The Taipan will be out shortly as well just too make your decision that much harder as if it already was easy.</div><div></div><div>If you want opinions then tell us want you want to do with the system and the cash you have on hand.</div><div>I sell the Mako BUT I won't give you advice that in my opinion will be wrong and you haven't given enough information for any kind of correct suggestion.</div><div></div>
