RE: Polyester fabric
Ceconite is very easy to work with. It will shrink a lot with heat though so make sure you have a strong enough structure under it to withstand the shrinking. A very close weave material and goes around compound curves with ease. You do have to use your own adhesive though as described in some of the comments above.
