RCU Forums - View Single Post - Flaps/Camber....when to use
Old 11-18-2012 | 05:30 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Default RE: Flaps/Camber....when to use
Wow so many questions LOL. First, for a winch launch you will want a touch of camber. The amount depends on the airplane but start consevitive. I also use a mix that adds camber as elevator is applied. When circling in lift I also have a slider set up so I can manually add some camber. In zero lift or sink you want zero camber. You need to be able to travel effieceintly.
