ORIGINAL: hrrcflyer
Jamie,
I have a dumb question for you. In the first picture you sent, what is the short rod with the ball links connected to the middle of the rudder servo for?
David
David,
that's a good one. I was wondering the same thing at first and then I realized that it probably is a "servo stabilizer". The rudder servo wants to be very firm in place and one way to "cement" it is to lock the output shaft in place by using a firm short pushrod anchored to the plate. The ball links allow the servo arm to rotate but the lock rod keeps it from moving fore-aft or side-to-side.
Jamie, please correct me if I'm wrong.
David
