RE: CDI gr8flyer55
<div>I don't think we are at a point when we can lock-down the PCB design of the 683, at least until Jake splits the development of the 2 processors. everything that has be done so far has been development work. Once the 683 is locked down a separate thread for the 1840 should be made. As for documentation, yes this needs to be taken care of asap and a summary would be best. If a new thread is started I recommend that it be switched to RCGroups, this way posting / uploading of files won't be a hassle. Jake and John if you guy's are ok with that I'll start a RCG thread for the 1840.
>There should probably be three threads for this project. One for hardware development, one for software development, and one for questions and helping new users.
Since the hardware and software go hand-in-hand, there should be a 683, 1840, and a help thread. After your next change, if it is common, keep the thread as is for now otherwise split the dev. and the threads
I've been working on a program flow chart for newbie’s which makes things a lot clearer to follow. We need to co-ordinate the rest of the docs. (PCB,Sch, and so forth) any volunteers?
Ray</div>
