RE: ARIXTRA Build Thread by ISAAC NAJARY
Is the repair made from balsa that has been glued to that ply 'bracket' and the fuse? I don't mean to pick on the mistake - it is a learning opportunity as the repair is in a fairly critical area. I may encounter something similar if I end up playing with my wing tube/ socket / incidence when I build my foam wing cores.
