RCU Forums - View Single Post - CDI gr8flyer55
Old 11-22-2012 | 10:41 AM
  #868
nyemi
Default RE: CDI gr8flyer55
ORIGINAL: Gompy
I realy dont know if there is a aircap, the tranformer is standard from John.
I broke the ecore and have to glue this one, so this one have a aircap thats be sure
Now i use a big transformer with IRL540, but i think I can use smaller FETs like TO92 case.
The question....wat type do I need, there are a lot.
<span lang="en" id="result_box"><span class="hps">I</span> <span class="hps">tell you</span> <span class="hps">from experience</span><span>.(</span></span><span lang="en" id="result_box"><span>push - pull)</span>
<span class="hps">The transformer</span><span>, ferrite</span> <span class="hps">core</span> <span class="hps">center</span><span>:</span> <span class="hps">0.1 mm</span> <span class="hps">air gap</span><span>.</span>
<span class="hps">The three</span> <span class="hps">core:</span> <span class="hps">the adhesive is</span> <span class="hps">suitable.</span> <span class="hps">(0.05 mm)</span></span>
<span lang="en" id="result_box"><span class="hps">I</span> <span class="hps">shows</span> <span class="hps">an example</span> <span class="hps">circuit</span><span>.</span>
<span class="hps">If</span> <span class="hps">you</span> <span class="hps">need</span> <span class="hps">small</span> <span class="hps">circuit</span><span>.</span>
<span class="hps">Do not</span> <span class="hps">insist on</span> <span class="hps atn">"</span><span>ZVS</span><span>"</span> <span class="hps">inverter.</span>
<span class="hps">Because its</span> <span class="hps">performance is very</span> <span class="hps">high.</span>
<span class="hps">The</span> <span class="hps atn">"</span><span>ZVS</span><span>"</span> <span class="hps">Motorcycle</span> <span class="hps">ignition</span> <span class="hps">is perfect.</span>
<span class="hps">The</span> <span class="hps">ignition</span> <span class="hps">engine</span> <span class="hps">model</span> <span class="hps">airplanes</span><span>,</span>
<span class="hps">rather</span> <span class="hps">transistorised</span> <span class="hps">push - pull</span> <span class="hps">inverter</span> <span class="hps">recommend it.
</span></span>
