RCU Forums - View Single Post - Antique gasser with modern ignition?
Old 11-22-2012 | 01:20 PM
gr8flyer55
Default RE: Antique gasser with modern ignition?
If you are going to use a hall sensor and put a magnet in the hub, you can use Autoadvance feature, although without a throttle, there is no reason to use it. I have some units without Autoadvance. I could send you a diagram on a setup I used.
John
