ORIGINAL: gaRCfield
Is the repair made from balsa that has been glued to that ply 'bracket' and the fuse? I don't mean to pick on the mistake - it is a learning opportunity as the repair is in a fairly critical area. I may encounter something similar if I end up playing with my wing tube/ socket / incidence when I build my foam wing cores.
Hi Joe,
First the balsa patch has been glued to the fuselage and were sanded align with the fuselage inside.
The ply bracket has been glued after that.
Best regards,
Isaac Najary
