ORIGINAL: ingleburn
Hahaha 5th flight and I split the tail boom. Told you I know how to break anything.
Man your tough on your helis
I got the hobbyking 6 split cable but I think any of them with the eflite ultra micro will do the trick.
You can get two charging by using your mcpx charger. There should be an adpater on the charge lead. Take that off and it's got the ultra micro connector. Change your mcpx charger to do .3 or .4amps max though not .7 when you charge them.
Jonesy
