With experience, you will get better at not getting ca glue on your fingers.
Iwould NOTuse acetone on your hands. your boddy can soak up acetone and cause health problems later.
It does not take long for CA to wear off body parts. When I epoxy and sometimes when I CA, I use cheap latex gloves.
My LHS sells long tips that fit on to CA bottles for about $0.25. After using the CA I will hold the CA bottle up and sqeeze the bottle a little to clear glue from the tip.
This usually works well. some times the tip gets gummed up any way. I just cut a small part off of the long tip.
</p>
