RCU Forums - View Single Post - RC Surfer
Thread: RC Surfer
Old 11-23-2012 | 09:07 AM
  #5962
YPC's Avatar
YPC
Default RE: RC Surfer
HOT 'little' TIP..........TESTED !
Water entering up the stuffing tube is generally overcome by 'Greasing' the drive shaft within the stuffing tube. The down side can be - hassle - power sapping - messy.
I have run a few surf tests now,with a short piece of Silicon tube fitted over the end of the Brass stuffing tube / over a portion of the extending drive shaft. (tube ID equal to the drive shaft OD) I have only 'very lightly' greased the drive shaft..........nett result.... less drag - less mess - no water whatsoever comes past the silicon tube. ( acts like a crankcase seal on a crankshaft)
Brp ********. ...
Share the STOKE !
