ORIGINAL: ahamay
ORIGINAL: ingleburn
Hahaha 5th flight and I split the tail boom. Told you I know how to break anything.
Man your tough on your helis
I got the hobbyking 6 split cable but I think any of them with the eflite ultra micro will do the trick.
You can get two charging by using your mcpx charger. There should be an adpater on the charge lead. Take that off and it's got the ultra micro connector. Change your mcpx charger to do .3 or .4amps max though not .7 when you charge them.
Jonesy
Thanks Jonesy, I forgot about that. Got a couple of chargers so that will get me out of trouble till I order the 6 way one.
In all fairness a crash didnt break the boom. Tried inverted and it got stuck in a tree. Shaking it out with a pool pole broke it.
It takes a lot less pitch to fly inverted. Gave it the same as the MCPX and it took off for the sky.
Hows fatherhood treating you?
