RCU Forums - View Single Post - Jetcat smoke pump
Old 11-23-2012 | 08:41 PM
Guillermo Ibanez's Avatar
Guillermo Ibanez
Default RE: Jetcat smoke pump
ORIGINAL: Guillermo Ibanez
ORIGINAL: furloughed ual
The pump is great...one of the best on the market for producing great smoke. The problem is the circuit board. Loosen the Allen screws on the pump casing and pull the pump and control board out. Look at the back of the board. Chances are there is a circuit there that you will see has burnt thru. U can reconnect it by soldering a small connector wire. That sometimes works. The other solution most do is to just use an electric motor ESC and connect that to the positive and negative leads of the pump and run it via the ESC. It will produce great smoke this way. I know it's a pain, but a much better and cheaper solution to throwing it in the trash and buying something else.
Thank you
I will give a try
HI:
I dissasebled the pump and found a microchip broken. Where exactly should the small connector wire be soldered? I tested the pump connecting a battery directly to the + and - terminals and it works fine but without speed control
Attached are two pictures, The microchip broken is the one that is on topofthe two that are together
BRG
ID:	1823198   Click image for larger version
