RCU Forums - View Single Post - 1650 problems
Old 11-24-2012 | 03:55 PM
Dr Honda's Avatar
Dr Honda
Default RE: 1650 problems
Well... we got a good running engine !!! But, we did have a few issues that we smoothed out. The biggest problem was that I wanted to try to start the pump slower... and I guess as I set the ramp down to Auto+0... it went one step more... and looped around to 255. Needless to say... we had a HUGE fireball. But, we got it shut down, and hit with the extigesher in time that there was no damage.
It was lightly snowing, and right at freezing... but we made a few adjustments. So, for anyone looking at this... Here are the final settings we used. (this is a new V10 ECU from Gaspar)
Start menu:
Pump Start Point AUTO +3
Pump Start Ramp 007
Glowplug Power 1.7v (using 2 cell lipo)
Gas Start Adjust 100%
Low Batt Volts 6,5V
Run menu:
Full Power Speed 110000rpm
Idle Speed 32000rpm
Stop Speed 20000rpm
Start/min temp 100°C
Max Temperature 750°C
Acceleration delay 024
Deceleration delay 018
Stability delay 065
Pump Limit 1000
