RE: Seagull Spacewalker II 120 Arf
WE JUST GOT THE CARB SET ON MY DLE 20cc) THE OTHER DAY>MINE WOULDN"T IDLE DOWN EITHER> I WAS about a 1/4 turn TOO RICH ON THE LOW SIDE> HERE IS WHERE WE HAVE IT SET NOW>>>>LOW SIDE IS JUST UNDER ONE TURN< HIGH SIDE IS JUST OVER ONE TURN>I think I maybe be a little lean on the high side because I'm only turning 8,500 rpm, should be at least at 9, 500
I have the stock ignition and it's just fine. I use a little expo in the throttle setting for a smooth throttle transition, and it's great.
Dan
