RE: fr5-300 oil vs fr7-420
Likely, it's because internal pressures at the metal-to-metal interfaces are lower, so the amount of oil doesn't have to be as high. OS knows what they're doing. Just make sure you use a good after-run product at the end of each flying day to get the steel parts well coated to prevent corrosion.
