RCU Forums - View Single Post - Low tail in turn
Old 11-27-2012 | 07:49 AM
rhall999
Default RE: Low tail in turn
Here is the simplest, easiest, and fastest fix..............
<span style="color: #ff0000">Use more rudder during your turn</span>.
Easy as that.
What it sounds like to me is that the tail volume is not quite right for the size/design of the rest of the airplane, so the tail is dropping when in the turn. You mentioned that it looks the same as a Cub, well, the fix for that problem with a Cub is to use more rudder right??? So, do the same with this airplane.
