ORIGINAL: hrdflite
this probably adds to the confusion,the mold dated 83 also has SA on it always assumed it was super arrow the one marked SA is slightly shorter.
Rob,
thanks for the pics. You are right, it does add a bit to the confusion. Are these the only two Arrow molds from which you are producing? If so, wouldn't it make sense to refer to your 83 mold as the
Super Arrow and the later mold as the
Arrow 800 as written on it?
The Arrow 800 would be just what it says - a larger Arrow with 800 squares, longer fuse and pipe tunnel. On the other hand, the Super Arrow would have the same specs (length and span) as the original Arrow with a longer pipe tunnel.
Is that the case?
Are you able to layup fuses using the Arrow 800 mold?
David
