RCU Forums - View Single Post - RC Surfer
Thread
RC Surfer
11-29-2012, 12:49 AM
6005
bearcave
RE: RC Surfer
YPC
Knowing how much you like 'fins' i dug out an old photo i copied off one of the ******** sites backthen but can't remember what the site was called.... The finswere called 'barracuda's' and I copied one out of brass sheet.
The extended prop tube in the photo was a bush type one i made and it is the same length as the original nqd one.... i just tried outa long and short shaft to suit.
billybongo.... the uni-joint i've been using is a Graupner bj17.... but my motor is the small shaft type 3mm..... they make a 5mm to 4mm one as well.... i still use the solid coupling to line up the motor to shaft if the motor has to come out.
Anyway not recommending anything just sayin what i did and showin the pics.
Surfcurls. lookin forward to seeing that board of yours going.... best of luck with the glassing...and the more i think about it reckonglassing a glass would be quite a challenge hey!
Reply
Like
bearcave
View Public Profile
Send a private message to bearcave
Find More Posts by bearcave
View iTrader Profile
