ORIGINAL: aquaflight
Direct quote from Haam "The fan is not responsible for creating low pressure at the front."
Well Haam - You must eliminate that fan for you to be correct.
Thank you for joining the discussion.
The fan, by itself, doesn'tcreate low pressure. But the low pressure takes place because of the actions of the fan. You see the fan creates a hole in the air. when this hole created air falls, flows, into this whole and the position of falling, flowing, becomes lower in pressure than atmospheric pressure.
