Andy, Rich, thanks. I can sleep easy tonight.
OK, I will do the final bind, then hook up the BB. One more question. Can I just run two battery packs thru the rx, direct ? Not planning on it, just curious. I am using three JR HD switches with the charge port. One on ignition, two on the dual batterys. I bind thru the switches. As far as I can see here, I only need to bind with one switch harness. Also usisng Smart-Fly Optic killer.
This should do it on the question subject, once it's bound, it's bound.
Good advice, appreciate it. I had laid off this stuff for about 2 years, getting back with the program.
Crank
Hobe Sound, FL
