RCU Forums - View Single Post - Help needed in debugging a fuel system fault.
Old 12-01-2012 | 03:28 PM
Jack Holland
Default RE: Help needed in debugging a fuel system fault.
Hi Ragz,
Everyone has been dancing around it. Pneumatic Resistance in the fuel lines between tanks. Hardware too small. This can cause leaks on a proven system, which will give the air bubble issue. I have switched to the large festo fittings from Tom Cook at Jet ModelProducts. I use the 3/16 ID tygon fuel line from the vents, thru the tanks, and Tom's fuel accumulator, to the pump. Any thing on the suction side of the pump is 3/16. Pump to turbine is usually 4mm which is fine. My Olympus is slightly stroked and performs flawlessly with this set-up. JMP has everything you need. An easy check is when you fuel up. If there is any swelling of any tank in your system, there is resistance.
Jack Holland
