RE: LiPo battery low voltage
I've heard damaged packs have a higher resistance. Lowers your max discharge and heat dissipated is based on i^2*r. I haven't personally messed around with over discharged packs but be careful! I'd keep an eye on temps and puff when you discharge it. If the cells are imbalanced that could be worrisome.
