RCU Forums - View Single Post - First bipe
Thread: First bipe
Old 12-02-2012 | 10:52 AM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Default RE: First bipe
ORIGINAL: acerc
More of the same here. I have a Waco, Stearman, Ultimate, and all of them do not like to land slow. Generally4-6 clicks of throttle trim does real well. Once the wheels are on the ground I bring the clicks back down. Of course I don't use that method anymore since getting a feel for it. The only other attribute I have found is useing rudder really helps in turns. For me without rudder the tail seemed like it wanted to loop around. Kinda slide outward away from the turn.
Good luck.
Most of this sounds like trimming issues. Yes a bipe is draggy and will require some power on final but have more wing area then a mono so should slow down nicely. The rudder in the turns thing is most likely an adverse yaw caused by a lack of aileron differential.
