RCU Forums - View Single Post - MFU hookup
Thread: MFU hookup
Old 12-04-2012 | 01:01 PM
tomhugill
Default RE: MFU hookup
Ok first off unplug the deans connectors you have between the mfu and the motors. Then plug a pair in to one motor, test it if it runs the right way and keeps running when you steer then you have it wired correctly. Repeat this with the with the other connection, that should give you a tank that runs correctly.
