RCU Forums - View Single Post - HANGAR 9 PULSE 125 XT
Old 12-04-2012 | 01:49 PM
bikerbc
Default RE: HANGAR 9 PULSE 125 XT
Tailskid did you glue your tail on? if not do you have any movment with just the bolts? I found that I could tighten mine up and stop all the movment but it would eventually start moving again and then my control would get sloppy so I glued it on and that cured the problem ..It is much better now...I did not over glue it in case I ever want to remove and replace it....
