RCU Forums - View Single Post - Using a Servo modified as a motor for elevation with Clarke board?
Old 12-05-2012 | 06:56 AM
tsull's Avatar
tsull
Default RE: Using a Servo modified as a motor for elevation with Clarke board?
I almost waited for the new board - but I received an email from Clarke(?) that those boards would be programmed for newer tanks. It might be awhile until WWII tanks are programmed. It's unfortunate that there was not a memory card capability for those controllers. You could than sell the sound cards.
It's my understanding that the Taipan card will have that ability?
QUESTION: I've read several DIY on how to make a servo a continuous motor, but if I just want it to operate as a motor (no Signal) in a 90 degree sweep as a normal servo would, is it the same process as making a continuous servo motor except you do not remove the stop on the gear system?
You would also need to throttle down the power supply by using the resistor(s) to lower the voltage to 4.6v(?).
A great DIY Tutorial on this would be great! hint hint
tjs
