RCU Forums - View Single Post - 1/5 Fokker Drl's
Old 12-05-2012 | 09:21 AM
texasclouds
Default RE: 1/5 Fokker Drl's
ORIGINAL: ARUP
Made new axle tubes to accommodate new wheels. Cut tubes to length, drilled holes, soldered washer then soldered unit to axle stubs. Cotter pin with another washer retains wheel. Do y'all wanna see what else was done to make these things a little better (at least to me)?
Do you glue the tubing to the axle to keep it from sliding off? wheel spins freely on the tubing?
