RCU Forums - View Single Post - Replacement for displacement.
Old 12-05-2012 | 10:54 AM
80sPattern
Default RE: Replacement for displacement.
ORIGINAL: eness76-RCU
I have seen a couple times in this thread that 5S is mentioned as the preferred SPA setup, but I can tell you as an active SPA flyer and electric flyer, I have never seen a 5S setup in SPA. Everybody is running 6S. Most guys are using that 6S with lower Kv motors to spin props more comparable with a 4s 91, but I made my propulsion target more along the lines of what the airplane was designed for. With regard to the extra weight of 6s over 5s, my Phoenix is 6lbs-4.5oz up all battery in and ready to fly. If I built another I'd probably shoot for 7lbs to handle turbulent air a little better. When choosing my setup I wanted my Phoenix to fly in the same flight envelope as our old Phoenixes did in the old days. I can assure you it is no WindS with Curare decals, and I doubt it sees 60mph even on the uplines. It may have fixed gear and be a taildragger, but it flies like a classic patternship was designed to. Jamie Strong could attest to that. At the Masters in Chattanooga he was flying a Dirty Birdy with a Nova Rossi on it and my Phoenix was faster.
Eness,
Iappreciate the info you have provided. Iam sure your P-5 is plenty fast. Ithink it is great that you tried to make your P-5 fly like it has a 60 in it. As you stated, you are being true to Don Lowe's design while using a modern power plant. Iam a believer is converting to E-Power but staying true to the design. My C4e flies exactly like it would ifit had a YS 61 in it which is was designed around. Your low weight is great advantage that allows you to have plenty of power while staying within the SPA guidelines. Iwould be happier with my C4e if Icould drop a pound. However, the Conqust IV is a BIG airplane, compare it to the P-7's in the photo below.
BJR,
Keep the comments coming. Ithink this conversation is really healthy. When Idecided to convert my C4e in 2011 there really wasn't much on the web to guide me. (Ihave to admit, that was part of the challenge)
Rendegade,
Thanks for starting this thread and providing us a place to discuss E-Power in Classics.
Doug
